Beta DS 4.11: Iray Fallback to CPU - Late 2013 iMac (4G 780M)
Rendering a simple scene, it falls back to CPU.  Log file shows this message:
2018-10-31 18:37:17.105 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(304): Iray ERROR - module:category(IRAY:RENDER):   1.2   IRAY   rend error: cuLinkAddData: unknown error
2018-10-31 18:37:17.125 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(304): Iray ERROR - module:category(IRAY:RENDER):   1.2   IRAY   rend error: cuLinkComplete: unknown error
2018-10-31 18:37:17.133 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(304): Iray ERROR - module:category(IRAY:RENDER):   1.2   IRAY   rend error: Errors: error   : Undefined reference to 'lambda' in ''
2018-10-31 18:37:17.255 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(304): Iray ERROR - module:category(IRAY:RENDER):   1.2   IRAY   rend error: cuLinkAddData: unknown error
2018-10-31 18:37:17.271 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(304): Iray ERROR - module:category(IRAY:RENDER):   1.2   IRAY   rend error: cuLinkComplete: unknown error
2018-10-31 18:37:17.280 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(304): Iray ERROR - module:category(IRAY:RENDER):   1.2   IRAY   rend error: Errors: error   : Undefined reference to 'lambda' in ''
2018-10-31 18:37:17.280 Iray INFO - module:category(IRAY:RENDER):   1.2   IRAY   rend info : JIT-linking wavefront kernel in 0.146s
2018-10-31 18:37:17.280 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(304): Iray ERROR - module:category(IRAY:RENDER):   1.2   IRAY   rend error: failed to link: device kernel image is invalid
2018-10-31 18:37:17.280 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(304): Iray ERROR - module:category(IRAY:RENDER):   1.2   IRAY   rend error: CUDA device 0 (GeForce GTX 780M): device kernel image is invalid (while linking MDL in core_renderer.cpp:237)
2018-10-31 18:37:17.280 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(304): Iray ERROR - module:category(IRAY:RENDER):   1.5   IRAY   rend error: CUDA device 0 (GeForce GTX 780M): Scene setup failed
2018-10-31 18:37:17.280 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(304): Iray ERROR - module:category(IRAY:RENDER):   1.5   IRAY   rend error: CUDA device 0 (GeForce GTX 780M): Device failed while rendering
2018-10-31 18:37:17.280 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(304): Iray WARNING - module:category(IRAY:RENDER):   1.5   IRAY   rend warn : All available GPUs failed.
2018-10-31 18:37:17.280 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(304): Iray WARNING - module:category(IRAY:RENDER):   1.5   IRAY   rend warn : No devices activated. Enabling CPU fallback.
2018-10-31 18:37:17.280 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(304): Iray ERROR - module:category(IRAY:RENDER):   1.5   IRAY   rend error: All workers failed: aborting render
GPU is correctly used for the same scene in DS 4.10
Is there a Mac NVIDIA driver I don't know about?  The Web driver is up to date for this OS (Sierra)
    What do you define as a simple scene? How much Vram for your 780M? If it's 4 GB, you won't be able to render much. How much Vram is used for whatever else is running?
  • Right now there is a problem with the nvdia drivers for mac, no updates available so it has reverted back to os default graphics drivers. It is the cuda driver that is causing this.
