FaceShifter For Genesis 8 Male
FaceShifter for Genesis 8 Male by InTheFlesh
A collection of 48 Facial Expressions for Genesis 8 Male.
Custom sculpted based on FACS (Facial Action Coding System), these expressions will add additional realism to your facial animations or poses.
Use individually, or combine with other expressions for increased flexibility.
Originally optimized for Faceshift with 1 to 1 mapping for easy import, but can be used for many other purposes.
Shaping Presets for the expressions will show in the Content Library under People\Genesis 8 Male\Expressions\InTheFlesh\FaceShifter G8M
Expressions can be found in Parameters\Genesis 8 Male\Pose Controls\Head\Expressions\FaceShifter G8M
Download from Gumroad for $0, or pay what you like to show your support:
https://gum.co/iIjdl
Or, download at ShareCG:
https://sharecg.com/v/92530/view/21/DAZ-Studio/FaceShifter-For-Genesis-8-Male
  • SixDsSixDs Posts: 2,384
    Very, very cool, Intheflesh. Thank you!
  • Thank you so much, they look really good. Can't wait to play with them!smiley
  • Recieved a question about how to export the morphs. Instructions below:
    You can download a CSV file of all the morphs here: http://www.inthefleshart.com/freebies/FaceShifter_Export_Rules.zip. Unzip the .CSV file.
    When exporting to .FBX, you need to edit the morph export rules to specify which morphs you would like to export.
    At the bottom of the window that opens when you click "Edit Export Morph Rules..." there is a button that says "Import CSV Rules". Click it, and navigate to the .CSV file you extracted from the downloaded .ZIP linked above. NOTE: THIS WILL WIPE ANY OTHER MORPHS ALREADY LISTED. CLICK "EXPORT CSV RULES" FIRST TO SAVE A COPY OF YOUR CURRENT MORPHS TO EASILY RESTORE LATER.
    That will import all the morph rules to export FaceShifter morphs. Depending on other morph packages that you own, additional morphs may be exported as well if they are similarly named.
    Please note this will override any other morphs you already have set for export. After importing the .CSV file you can still add any other morphs you'd like to export too.
  • Tramp GraphicsTramp Graphics Posts: 2,433
    I would love these for the original Genesis base.
  • Worlds_EdgeWorlds_Edge Posts: 2,153
    Thank you.  I downloaded from gumroad.  Do we install it the regular way?  Are the special instructions about importing csv files etc meant for other than standard use in DAZ Studio?
  • Thank you.  I downloaded from gumroad.  Do we install it the regular way?  Are the special instructions about importing csv files etc meant for other than standard use in DAZ Studio?
    Just copy the folders into your daz studio library and everything should work fine. Correct, the CSV file is simply for use when exporting characters from daz studio to fbx format and isn't actually required.
  • Thanks for this! It's great! There are some blendshapes missing though.. I have a question: I've modeled the missing ones (LipsUpperUp_L, LipsUpperUp_R...) using PowerPose in Daz Studio. Do you know how can I add them to the other blendshapes you made so I can export everything in Faceshift? I saved the poses as .duf files in My Library Faceshifter G8M folder and added them as morphs when exporting the fbx file but still they don't show up in Faceshift Studio. Do you know what could be the problem?
  • In The FleshIn The Flesh Posts: 157
    edited November 2019
    FaceShifter for Genesis 8 Male: The Missing Morphs Update
    I finally manged to snag some spare time between projects to update FaceShifter with some missing morphs.
    The original FaceShifter posts have been updated with the new files, this contains the updated morphs only.
    Copy files to your Daz library
    Cheers,
    Daniel
    Download the update from your Gumroad library
    https://sharecg.com/v/94801/browse/21/DAZ-Studio/FaceShifter-G8M-Missing-Morphs-Update
    Also updated the .CSV file for easy morph export
    https://sharecg.com/v/94802/browse/21/DAZ-Studio/FaceShifter-Morph-Export-.CSV
    1575 x 1802 - 2M
    Post edited by In The Flesh on
  • December 2019 update has been released, as well as a new video to show installation and usage:
  • Very coll expressions. I like them and will be very useful for future art.
    Thank you very much !
    Merry Christmas!
