Body add-ons; wings, tails, horns, etc?
Chiza.albaChiza.alba Posts: 0
Hello! First of all I'd like to say thanks for tolerating my many newbie questions, this forum has been very helpful. :)
Today I'd like to understand how to add fantasy body parts to a model, whether a Daz model or a custom one. I'm creating a series of characters with features like wings, horns, and tails. With my current knowledge, I think I can handle modeling and rigging these without help. What I'd like to learn is how to attach them to the body of my model. Is there a tutorial on this somewhere? Thanks in advance!
  • Richard HaseltineRichard Haseltine Posts: 111,363
    In general you want the items to match the parent figure's grouping and positioning at the point of joining, then you can use the parent figure as a skeleton donor, add the extra bones needed for the item, and make it a conformer. For Genesis (and any other TriAx rigged figure) in DS4 you can also match the precise vertices at the joint ad use GeoGrafting to attach the item more smoothly.
  • Chiza.albaChiza.alba Posts: 0
    Thanks, Richard. I found a tutorial here: (http://forumarchive.daz3d.com/viewtopic.php?t=184183&postdays=0&postorder=asc&start=0) about geo-grafting and was able to pull it off with a simple graft item. I'm not sure what you mean by skeleton donors and conformers, though. Could you explain that a little more please?
    If a figure, not a static prop, is to follow another figure then it needs to have the same bone names and locations for the application to match it up - it can then have extra bones beyond that, as a wing would, but it needs to overlap and match in part. otherwise you can simply parent the add-on figure to the appropriate part of the parent figure.
    Thanks for explaining. The tutorial I read seems to cover that, the Transfer Utility gave the graft item all the same bones as Genesis. What the tutorial did not cover was how to save grafts to a figure. I've created and rigged my own character, which I'm going to graft wings, tails, horns etc. to. I'd like the grafted items to already be attached when I load my character. How do I do this?
    Anyone know the answer?
    Sorry, I missed your reply when the forum ate my new post markers. You need to export your add-ons as DSF figures in order to preserve the setup information for grafting. File>Save as>Support Asseet>DSF Figure or prop, as I recall (the menu location has been soemwhat changeable as new betas have been released).
  • I know this is a discussion from 2012, but sadly the link referred to earlier in this discussion no longer exists. It is exactly what I want to learn.  Does anyone know if that link is available elsehwere?
