Iray is not rendering the scene?
Hello Guys
I was working normally, suddenly, I started to render in Iray and my screen become gray. What I've done?
Render settings is default and I already tried to put a Iray light... nothing!!!
1920 x 984 - 195K
  • You don't have a Section Plane lurking in the scene?
    You may have to scrap it and start again.  I've run into this on occaision, all of a sudden it simply won't see anyhting in the scene. Haven't been able to figure out why but usually, the scene is corrupted and you just have to start over.  Try a different scene and see if it works.
  • I had this happen recently. The saved scene file was just plain corrupted. No matter what I did it would not render. Reloading Daz and rebooting the computer didn't help. Stuff happens. If the scene is important and is taking a long time to setup I strongly suggest saving at many points along the way in different files. That way if it all blows up for some reason you can always go back to before that point.
  • If you get apparently corruptd scenes like this please open a bug report (Tech Support ticket) with the scene attached, and a note of the content used.
    Yes, my document was corruptd... I had lost everything. Thank you, guys!
