Downloads folder
jedijuddjedijudd Posts: 606
edited October 2018 in The Commons
Can I delete everything in the downloads folder for install manager or will that effect what I have installed, or will I not get updates for that product anymore? It is 432 gigs if I could delete that it would be a life saver
Post edited by jedijudd on
  • Phoenix1966Phoenix1966 Posts: 2,001
    You can delete it without issue. If you need to re-install something, you will simply have to redownload the file.
  • jedijuddjedijudd Posts: 606
    Thank you for the answer
  • dragotxdragotx Posts: 1,149
    edited October 2018
    I've had to reinstall Studio often enough that I personally recomend keeping all of the downloads in a storage drive, so you don't have to download them all again of you ever have to reinstall. Large capacity drives have gotten pretty cheap these days, and keeping the files can save you a lot of time when you have to rebuild
    Post edited by dragotx on
  • I've got them set up on a 3TB external drive to start with.  You can store the files wherever you want when you use DIM.  The reason I don't just archive them is it's difficult to see what has been updated that way.  The one thing you don't want is to have them running around on your C:, that isn't necessary.
    Thanks for your suggestions i moved them all to a external
