Fit Control for Genesis 3 Male
Hi all,
Ok, so I tried applying it to his clothes and then this happen when I used one of the morphs. Can anyone please explain what might be happening?
Thanks!
955 x 881 - 754K
  • barbultbarbult Posts: 27,579
    The pants probably use a geograft to hide the persons body under the pants.
  • ok thanks but what does that mean in plain english?
  • edited October 2018
    If look like this seems trousers became smaller and he became invisible man surprise
    Can you screenshot how fit clothes without apply morph and sequence of morph you apply?
    Post edited by marco_pasqualini_foto on
    A geo-graft is new mesh geometry that is grafted to and replaces part of the figures mesh geometry.
  • If look like this seems trousers became smaller and he became invisible man surprise
    I simply loaded the character and the outfit, then applied the fit controls to the character. Once that was done, I set "down all" to a value of 150. No other modifications were made. It should have worked!
    The "fault" is not with Fit Control. The pants are hiding the figure's geometry. If you load these pants on the figure and then hide them by clicking the eye icon next to them in the Scene pane, you will see that the figure geometry is already invisible, before you even dial in Fit Control morphs. Some vendors do this to prevent poke through of the figure through the clothes. Nikisatez  does this a lot, or at least used to. Try different pants and it will probably work fine. Or, you can go to the trouble of removing the geograft from the pants you are using. Here is a forum post about this.
  • Alright so say I buy other outfits for G3? How can I tell if they have geograft or not?
    I don't believe there is any way to tell before purchase.The majority of products, especially for men, will not use the geograft. However, you are covered by a 30 day guarantee. You can return a product that doesn't satisfy you. To return a product, submit a help request and select the Sales category (instead of Technical Support). Refunds are usually no hassle. Just explain which product you want to return, why you are dissatisfied, and include the order number.
    Here are a few G3M pants products that I know do not use the geograft technique.:
    Civilized Man for Genesis 3 Male(s)
    Montana Outfit for Genesis 3 Male(s)
    Millennial business Casual Outfit for Genesis 3 Male(s)
    Jeans and button Up Outfit for Genesis 3 Male(s)
    Here is the Fit Control "Down All" on the Jeans and Button Up pants.
    1708 x 1798 - 177K
