DAZ3D 4.10 Product Updates
Some of my new products (installed via Install Manager) show an update available with the little circle-arrow in the upper right corner. I right click on the circle, and select "install update".
The thumbnail turns B&W, and slowly from top to bottom converts to color. When it is 100% done (watching the little progress bar in the status line at the bottom of the screen), the icon is back to color, and the circle-arrow is back.
Here are a few products that it keeps doing this with Basic Hair, Charm Hair, all of my Dream Home assets, Vianne for Victoria 6... just to name a few.
Why? And, is there something I can do to fix it?
Right-click on one of the affected products and select Browse to Folder, then scan through the contents - are there some .part files in there?
Yes, there are .part files in library/props folder.
OK, this is a download that is either failing to complete or failing to decrypt. Another user had a similar issue recently, so I will link you to a post I made setting out the options I am aware of https://www.daz3d.com/forums/discussion/comment/4053301/#Comment_4053301
I checked that out. I've copied the steps to a text file. I'll give it a try and see how it works. It might be a day or two before I'm up to trying to fix it.
