Tested a FBX converter to use this format in Bryce
I have find a converter to use FBX files in Bryce (converted to obj).  Although not perfect it does the job.  Seems though that sometimes things go slightly wrong as seen in the sleeve of 1st mannequin which do not show nicely.  In such event postwork needs to be done I suppose.  I was searching for male mannequins and got this.
Although converter work one needs to smooth the model first.  If not, textures do not apply.
1194 x 563 - 345K
1194 x 563 - 276K
  • SlepalexSlepalex Posts: 911
     Although bryce provides for importing FBX files, I could not load one. Apparently, modern FBX files are somewhat different. Moreover, some files can not be converted to an online converter. Mostly this is a freebie from https://sketchfab.com/ and from https://www.cgtrader.com/
    In addition, there are restrictions on file size.
    Laura, if you can send me this converter by mail, I will be very grateful.
    I've often found this one reliable for converting files to different formats to bring into Bryce. http://www.greentoken.de/onlineconv/
    Don't think I've ever tried FBX, but I have used it quite a lot for other formats. There are also options to upload the model's materials to make those compatible your output format too.
    Dave, I use this converter most often. There seems to be a 50 MB file size limit. It spits onto some FBX files.
    Here are not very reliable converters:
    https://www.meshconvert.com/
    http://www.swiftconverter.com/convert_3d
    Thanks for those Alex, it's always good to have plenty of options. smiley
  • launoklaunok Posts: 807
    Slepalex - Have send you mail, but I can just as well share the link here for others since it's available directly from Autodesk site.  This is not an online converter, you can download it and install directly on your computer.  I am using 64-bit version but other versions also available.
    https://www.autodesk.com/developer-network/platform-technologies/fbx-converter-archives
    Thank you, Laura. I will try.
  • JamahoneyJamahoney Posts: 1,791
    edited October 2018
    Interesting, Laura.
    Jay
    Post edited by Jamahoney on
    I installed this converter, opened it, did not understand anything and closed it.
  • StuartBStuartB Posts: 600
    Here ya go Alex.
    Hope this helps.
    1032 x 737 - 101K
    1033 x 744 - 150K
    1027 x 739 - 161K
    1030 x 738 - 191K
    1034 x 742 - 210K
    StuartB said:
    Here ya go Alex.
    Hope this helps.
    Thanks, I will try.
