Chamfer only certain edges
Hi,
started using Hexagon and not really sure how the chamfer tool should work.
If I chamfer all edges of one side of a cube, everything works perfect, chamfer cuts loops and generates only quads.
If I try to chamfer only certain edges, chamfer just creates edges around the chamfered edge, resulting in ngons. (see attached image).
I've seen a workaround with extracted curves and ruled surfaces, but for a 2D chamfer issue.
Should chamfer work this way, is there an easy way to get loop cuts instead of only edges ?
1920 x 1040 - 264K
  • AscaniaAscania Posts: 1,856
    Select edge loops to chamfer.
  • ShawnDriscollShawnDriscoll Posts: 375
    edited October 2018
    Mazh said:
    Hi,
    It's just the nature of the beast is all.
    Post edited by ShawnDriscoll on
