Time of year and my fav pwGhost isn't working (SOLVED)
IkyotoIkyoto Posts: 1,159
[Time of year and my fav pwGhost isn't working] Tel me what info youneed to know.
Post edited by Ikyoto on
  • Oso3DOso3D Posts: 15,116
    Works for me
  • NorthOf45NorthOf45 Posts: 5,896
    3Delight only. Select figure, go to surfaces tab, select everything (depends on generation), and apply a shader preset. Make sure you are using the DS4 version, not DS3.
  • srieschsriesch Posts: 4,243
    Have you reinstalled your operating system or otherwise cleared out the DS program folder since the last time you used pwGhost?
    I'm not sure if/how DIM handles it, but if you are manually installing, on a fresh OS install or if the DAZ Studio folder ever needs to be rebuilt. Reinstall certain products that are half content and half in the DS program folder by unzipping pwGhost (or any similar products) into an empty temp folder.  Within the temp folder, locate the top level folder named something like “DAZ Studio_4.5;4;4.x Public Build;4.x Private Build”.  Open a second window to where DS is installed, (WINDOWS 7 PUBLIC) C:\Program Files\DAZ 3D\DAZStudio4 .  Browse through the matching subfolders in both windows until non-matching folders or files are found that are only in the temp folder, then copy those files/folders from the temp folder into the corresponding folder paths where DAZ is installed.
  • IkyotoIkyoto Posts: 1,159
    THAT'S why!!!  I was using the wrong rendering! 3DL... not iray... THANK YOU!
