Help, I've lost my pants!
Fungible UserFungible User Posts: 456
edited February 2019 in The Commons
Post edited by Fungible User on
    They look like football pants with leather shaders applied.
  • I have no idea about the clothing, but you have my vote for most amusing thread title of the year! laugh
  • Fungible UserFungible User Posts: 456
  • JUJUJUJU Posts: 1,133
    I have searched now for a not so little while but I cannot find it either... Looked through all my cloth stuff and opened uncountable account of pants...uhhhh....I hate searching without positive solution...
    seasailor said:
    Wow, first of all, "wow!", thanks for the effort. I did the same thing and looked at every single pair of pants in my library and then went through all the male outfits from Genesis to Genesis 8 in the store (and then it dawned on me, it might be female clothing - sigh). Some pant tops are actually hidden from view in the vendor photos so it's hard to tell. I mean, I could just run them up in Marvelous Designer, simple enough, but thought it might also be part of a cool clothing set.
    ...and it could be someting that will release "soon".... so.... I hope anybody can solve the secret.... I like the pants too....
  • BeeMKayBeeMKay Posts: 7,019
    The only thing remotely similar I found are these:
    Maybe they made a custom texture for football pants?
  • ALLIEKATBLUEALLIEKATBLUE Posts: 2,984
    CZ said:
    These look like they could be the ones but I wonder how the belt was removed. It's not seperate from the pants and the second picture is how it looks with the cutout opacity turned all the way off.
    936 x 901 - 958K
    936 x 901 - 952K
  • Assuming those pants have separate material zones for everything attached, the Geometry Editor could be used to remove unwanted items (ie. the belt, gem, etc). I use the Editor quite often to delete/hide objects, walls, clothing parts, and so on. It's also great for adding/altering material zones.
  • CZCZ Posts: 160
    You can also use the Surface tab, klick on the items left in the image and apply an invisible shader (e.g. one is included here: https://www.daz3d.com/pd-iray-shader-kit-2) or set the cutout opacity to zero for each surface.
  • CZCZ Posts: 160
    edited October 2018
    I think the pockets and stiches are only on the texture. If you look at the clay promos, there are no pockets. Also in the Texture Add-on Promos (https://www.daz3d.com/phoenix-outfit-textures) no pockets can be seen. You can try to apply any simple leather shader to get rid of these details.
    As I don't have the product, I can not test it. But I tried it with the Vigilante Outfit (https://www.daz3d.com/vigilante-outfit-for-genesis-3-female-s). Maybe you also like it. One Version is the original texture with some kind of pockets, the other one is just a simple leather shader, i found in my library.
    500 x 500 - 176K
    500 x 500 - 179K
    Post edited by CZ on
  • CZ, I like how they look on him. I think I'll be converting those eventually and trying them on the dudes. :)
    As far as the original pants, this is one that first came to mind and I have used them quite a bit. Obviously, they're not what the OP is looking for, but they are certainly a close likeness.
    https://www.daz3d.com/the-executioner-for-genesis
  • Silas3DSilas3D Posts: 835
    Please do let us know what DAZ says, I did spend some time looking through my own library and couldn't find them! I wish more vendors would do exploded promos of their clothing products like MeshItUp does.
  • CZCZ Posts: 160
    laugh Yes, I'm also very happy, that, while surching, I found those Vigilante Pants and that they fit so nicely to G8M. I already used them in some renders and surely will do again. I should look more often in old parts of the library instead of buying all the new stuff.
    But I also would like to know, what Daz says.
