How to open DAS files in C8.5p?
EddyMI3D
Hello there,
is there a chance to open a DSA material file in Carrara 8.5p or is there maybe a workaround.
I like to put some color onto Hitomi's ring hair.
Thanks in advance,
Eddy
.DSA material presets are script based presets, so they only work natively in DAZ Studio. I'm fairly certain Carrara won't read them. However, if you have access to DAZ Studio (and everyone does since it is free). You can use DAZ Studio to convert the .DSA file to a .DUF file. All you have to do is apply the .dsa material preset to whatever it is supposed to be applied to. Then select the figure and go File-->Save As-->Material(s) Preset. Choose a name, set your dialogue options (you can customize which surfaces, and which channels the material(s) preset affects). Save the file, and you can now load it in Carrara 8.5
Hi Jared,
thanks a lot for that hint!!
Eddy
