Morph Targets Tutorial (Great for Low Poly Figures)
Sci Fi Funk
How to use morph targets Tutorial. How to use morph targets for animation avoiding Poser figures and using low poly objects instead.
http://www.youtube.com/watch?v=7akhf5GFMAM
Morph targets allow the animator to define an area of an object, move it and then animate ("tween") between the two states (un-morphed and morphed).
The good news is that in Carrara the morph targets are keyframe animatable. Therefore you can take advantage of the facilities in the sequencer (such as easing in and out).
The reason I point this technique out for low poly figures is that with some care you can avoid having skeletons attached to your objects.
more at
http://www.scififunk.com
http://www.faecbook.com/scififunk
