Trouble installing LDP-R
sinfanysinfany Posts: 190
So, I got the latest version of LDP-R (for Mac) and it doesn't load into Photoshop!
I download the LDP-R (Mac) with the Dim installer and the smaller file LDP-R (Photoshop) manually (no other way). The problem is that even with the .atn file sitting in the Actions folder, it doesn't show up in the Actions menu. All 8 rendered files open in PS as separate files and I need to create a new file and place them individually as layers (not pretty!). And none of the filters were included.
In the downloaded (PS) folder was a Manifest.dsx file, separate from the folder with the .atn file. What is that file and where does it go?
LDP-R seems to work well enough in DS but not at all in PS6, which is the reason I got it in the first place.
I've looked all over to see if there is some step I missed in the install process. A txt file with basic instructions would have helped... : (
Has anyone encountered this?
  • Richard HaseltineRichard Haseltine Posts: 111,908
    I don't have LDP-R, but try going into Install Manager, clicking the gear at top-right to get to preferences, then going to the Applications tab, and clicking the + button to add a new application - select the version of Photoshop you have from the drop down, then select teh path to the application (not the plug-ins folder). Try uninstalling and reinstalling LPD-R.
  • TotteTotte Posts: 15,242
    edited September 2013
    I installed it on Mac OS X without a problem, but there is something in the documentation you should note.
    Open Photoshop, locate the Actions Window (if it's closed, open it with Windows→ Show Actions). Click on the small arrow at top right of the Actions Window and choose Load Action. Choose the Dreamlight LDP-R.atn file and click on Load
    Btw, the documentation pdf is linked from the READ ME
    Post edited by Totte on
  • sinfanysinfany Posts: 190
    Richard, did as you suggested with the install manager and it worked without having to uninstall!
    Totte, I actually clicked on the "i" icon in the install manager as you sent me the link and the Actions window now has the folder.
    Thanks guys - you never disappoint!
