How to subtract weight using node weight map brush?
Hi all, I'm trying to modify a dforce object, by making a part of immovable using the node weight map brush. My understanding is that I need to color it grey in order to make it immovable, with blue being somewhat moveable, and red being the most movable.
However, when I use this brush, I only make it more red, instead of grey. How do I use the subtract to make it grey? Thank you.
  • LeanaLeana Posts: 13,553
    edited October 2018
    IIRC you need to hold the "ALT" key while painting to substract.
    Post edited by Leana on
    Yes! Thank you, that's doing exactly what I want, hopefully!
  • - and on Mac..?
  • Opt is the Mac equivalent of Alt - you can see, and change, the modifiers used at the bottom of Window>Worksapace>Customise.
