Genesis 8 female
I hope I am posting this in the right place....
I can't find the base genesis 8 female on the daz3d.com site for purchase.
I downloaded the free "starter essentials" thinking they were giving her away like the rest of the characters, but everything was installed to "MyDaz3dLibrary/data and I can't find the Genesis 8 Female.duf, Genesis 8 female.png  or any textures.
I did get Morphs, Projection morphs, projection templates, tools, uv sets, and Genesis8female.dsf along with Female Eyelashes and Female Genitalia.
Is this all I need?  If so I don't have a clue as to where to put them in mylibrary?
Can anyone help me figure it out?
  • MelanieLMelanieL Posts: 7,867
    edited October 2018
    Are you downloading and installing manually? Or using DIM? Or Connect (installing from within DAZ Studio)?
    It sounds like you are doing it manually - if so you need to go here: https://www.daz3d.com/downloader/customer/files#prod_42071 and the file with G8F in is this one:
    When you unzip it, it should have a top level folder called "Content" - you need to move/copy everything inside that folder to MYDaz3dLibrary which should then have the following folders:
    816 x 529 - 74K
    785 x 116 - 18K
    Post edited by MelanieL on
  • How did you install, those files are the back-end asset files and should not be appearing in the content views in DS (and you won't get the genitalia without purchasing an adult female 8 Pro bundle for Genesis 8).
    If you were using DIM and it didn't install correctly, I suggest you uninstall it and try installing it again - it should be creating the same set of folders in the second image above.
  • BeeMKayBeeMKay Posts: 7,019
    edited October 2018
    You don't need to purchase G8F, they are part of the package. From your post, I take it you downloaded the Genesis 8 Starter Essentials?
    If yes, they contain the basic things for G8F and M.
    Did you install manually, or through the install manager, or through connect? (This is a Step-by-step about installing Non-DAZ content to DS, with images: http://www.daz3d.com/forums/discussion/comment/927004/#Comment_927004 but it should work for manual DAZ content installation, too.)
    I don't use Smart content, but in the Content Directory, you can find her when you follow People --> Genesis 8 Female
    1113 x 371 - 51K
    Post edited by BeeMKay on
  • OrjannaOrjanna Posts: 22
    Thank you so much for your help!  The link you added did the trick.
    Thanks Bee and Richard also.  :)
    Glad it worked .
