bend deforming morphs
I morph a character but bend alters the look of the morph in ways i dont want it to. Is there a way to get bend not to alter morphs and just bend the joint?
A picture like a screenshot would be nice to see what you are talking about. To take the screenshot open DazStudio and press Alt+Print, then paste (Ctrl+V) it ino some image editor and save it, next here in the forum post press Edit Post and Attach a File to choose the picture you just saved.
You can't literally do what you ask, but - depending on the cause of the issue -therea re a couple of things you can try. You may simply need to use adjust rigging to shape to accomodate the way the chnage of shape affects the bending, or you may need to create a corrective morph that kicks in only when both the bend and your morph are applied.
now that i had time to do an example this shows my probem i keep having when i morph and bend to much(though this is exagerated to show the problem).
The first picture shows when morph is correct, The second shows the problem I am having with multiple morphs(though no where near as exagerated as this) when I apply bend it alters the shape of the morph.
I have tried goinging and using other morphs to try to fix the problems when i have these most of the time I can get it fixed but sometimes I cant get it fixed like in this example.
