Apply expression to half the face only? (Upper/Lower). Newbie question.
Hey ya'll.
Beginning to climb the mountain that is attempting to learn Daz. Looking for tips or advice on this one.
Say you really like the eyes in an expression, but aren't crazy about the lower half.
Is there an easy way to "Lock" the upper part of the face while you try other poses for the lower half? Or perhaps is it possibe to apply expressions to only half the face?
EG, this product which has morph dials. https://www.daz3d.com/genesis-8-female-expressions Or any of the numerous products that have expressions.
Thanks for your input.
A lot of the Genesis 8 expressions (and Genesis 3 too) are driving bones in the facial rig, so to that extent it should simply be a matter of finding and zeroing the bones. Even where morphs are involved they may well be localised - those will be found on the figuire, under the Pose controls group in the Editor tab. If you also/instead need to halve the effect of a single morph then you would probably want https://www.daz3d.com/x-morphs , though ti is possible to split morphs with only DS by exporting as OBJ and then reimporting via Morph Loader pro using the attenuation options.
