Issues with Add-ons
Ok, so I've downloaded Victoria 5, but it doesn't seem to be coming up in the add-on list. I had moved all the Daz folders into a folder called DAZ, and now i have another "DAZ 3D" folder, with InstallManager inside it, and the Victoria downloads. Problem is, inside the DAZ folder I made, is DAZ 3D, with InstallManager, with the Victoria stuff.
Moreover, everytime I boot up DAZ, it asks me for aniMate2's serial code...which isn't appearing in my serial code list. What am I missing?
I am really lost here? The DAZ Install Manager is for installing content, and it installs by default into C:\Program Files (x86)\DAZ 3D\DAZ3DIM1. You should NOT install any content in there, it is for applications only.
DIM installs the content that it downloads into C:\Users\Public\Documents\My DAZ 3D Library by default, and that is where V5 should be installed to, along with Genesis Starter Essentials. Run the DIM, and allow it to install your content to the correct folder.
Animate2 - did you buy Animate2 as a separate purchase form the store? Animate2 is a paid for plugin and does not come as part of the free DS4.6 Pro. DS4.6 Pro comes with Animate Lite, but you may have the 30 day trial of Animate2.
Ack, forgot to remove this-I figured it out, I wasn't looking in the right menus on DAZ. As for the installing to it and whatnot, that was bad wording on my part, apologies.
Animate2 might of expired on me, which would explain it's code missing.
Although I do have one more question-supposedly content creator is included with D3DPro4, but I can't seem to find it. How do I activate it?
It is now built in tools, like Figure set up and others, Not one big tool. The sum of the tools in DS4+ is the full set needed to make content now.
