How do i remove the shaders?
Hey folks, I’d really appreciate some help. I’m a bit of a novice when it comes to shaders. I was experimenting and testing with a shader, doesn’t look the way I was hoping and now I can’t get rid of it. Tried looking at manuals and forums, can’t figure it out. How do I remove a shader or clear all shaders?
If you select the item in question and make sure the surfaces are selected, or like select the skin if the shader was applied to that, go to your shader presets and find the DS Defaults and the first one there is like Dzdefault or something similar, if you load in that shader it should get everything back to the default.
You can't "remove" a shader as every surface has to have some sort of a shader assigned to it. You can replace it with a default shader (like MikeDzBro suggests) or, if it's a character, prop, clothing, etc. you can usually re-apply the base materials that came with the content.
Thank you both for your help, you just saved me a lot of time! Dzdefault worked perfectly!
Glad we could help, Mike. I think you'll find people around here generally enjoy being helpful and seeing others grow in this hobby / artform.
