New install of DAZ 4.10 is behaving really oddly.
Octavia Moon
I've just installed DAZ 4.10 for the first time and it looks very different to what I'm used to. Clearly something has gone wrong, but I don't understand how to properly describe it well enough to start Googling up solutions. Could anyone advise me in any way as to what the problem might be?
My DAZ viewport currently looks like the first file (BadDAZ). I want it to look more like the second file (GoodDAZ). Thank you in advance for any information you can give me.
1025 x 906 - 170K
546 x 445 - 36K
That looks like a GPU issue - either using the wrong one if your system has two (check the control panel for the main GPU, not the Intel one on the CPU) or you need a different driver..
Thanks Richard. I've upgraded the AMD Radeon drivers and every other app/program on my system is reading from it (or at least displaying) just fine.
Can you advise which settings I should alter in DAZ Studio to help DAZ read from the correct GPU? I don't use DAZ for anything other than posing - I don't need to render at all.
It would be a GPU setting - with nVidia cards it is, I believe, in the nVidia control panel so for an AMD card I would expect it to be in the Catalyst control panel. There should be settings, per appl;ication, for which GPU they use - you can check which DS is currently using in Help>Troubleshooting>About Your Video Card.
Thanks Richard. We figured it out in the end. Appreciate the help!
