Use daz with remote desktop
Hello all,
i have search the web and forum for a solution for this..But havent found one.
i use a laptop (ok spec, gtx1070) and remotly connect to my render pc (gtx1080ti *2).
i use Splashtop Personal on both computers and it works almost perfect. I can navigate the sceen without lag.
But i can’t use the sliders to control rotation, placment etc for figures. Anyone know why?
BR//Daniel
  • Try using the Public beta, that has some updates to the remote access options.
  • Thanks for the answer.
    i dowbloaded latest beta, but with the same result.
    BR // Daniel
  • KitsumoKitsumo Posts: 1,222
    Are you using this through your local LAN or over the internet?
    Local network.
    Everything else works perfect.
    br // Daniel
    Local network.
    br // Daniel
    Darn. I was hoping to try it on my network.
  • Will, it is possible to work with it. I can put in a value with the keyboard and fine tune with slider.
    br Daniel
  • kaotkblisskaotkbliss Posts: 2,916
    Go into your streamer settings and see if you have the mirror driver installed under advanced settings. If you do, uninstall it. I use splashtop (the paid version for mostly out of network use) and don't have any problems with cube or slider :)
  • Go into your streamer settings and see if you have the mirror driver installed under advanced settings. If you do, uninstall it. I use splashtop (the paid version for mostly out of network use) and don't have any problems with cube or slider :)
    Thanks, will check later this week.
    br Daniel
