RSSY 3Delight to Iray Converter Issue
I'm using the converter on V4.2. Attached are test renders before and after I applied the 'rssy3dlti 01 victoria 4 material iray'. Can someone help explain what happened here?
840 x 525 - 115K
840 x 525 - 162K
  • StingerStinger Posts: 328
    And with the G2 converter I'm having mapping problems. Attached are test renders before and after I applied the 'rssy3dlti 01 genesis 2 female iray material'.
    840 x 525 - 130K
    840 x 525 - 132K
  • LeanaLeana Posts: 13,535
    Check the UVs used in surface tab, I wouldn't be surprised if the character initially used custom UVs and the material set it back to G2 default UVs.
    Thanks for the tip, Leana.  I tried the converter on the base Victoria 6 model, and the maps came out correct.
