please can someone help me having problems
my handgrasp is missing from my genesis 8 female characters
and also cant autofit clothing  can you tell me what i am missing  thanks so much please somone help me asap thanks
«1
  • The grasp controller comes from the Body Morphs pack, I think, so make sur that is installed.
    What happens when you try to AutoFit an item?
  • lasagnamanlasagnaman Posts: 1,001
    genesis 3 female doesnt show in the list it says unsuported   whats the body morphs pack can you send me the link
  • FenixPhoenixFenixPhoenix Posts: 3,237
    Are you trying to autofit to a G3F or are you trying to autofit a G3F outfit to another generation?
    autofit
    daz studio 4.11 wont install either  it wont show up on my desktop
    i try to install it from daz install manager it wont install  please help me with this  iam getting really pissed off
    I was wrong, Fingers Grasp is part of the Starter essentials, as is the Genesis 3 Clone for use in AutoFit. it sounds as if your instalaltion of Genesis 8 Starter essentials or Genesis 8 female Starter Essentials, depending n whether you used Connect or Install Manager, is broken - please try uninstalling and reinstalling. Also, is the Content management System running generally - do you have categories listed in the Content Library pane and in Smart Content?
    Is it giving an error, or appearing to install but not being available?
    i have another problem
    i cant install daz studio 4.11 or 4.10 with dim  it wont show up on my desktop
    i am installing it through the dim but it wont install it says its intstalled but its not on my desktop ail
    is daz studio 4.11 available manually instead of using the dim
    no that seems to be fine
    doesnt appear to be installed
  • Which question was "no that seems to be fine " to?
    For the applications, have you tried clicking the Start button/Windows logo button at lower-left and looking under Daz 3D in the folder list to see if the icons are there?
    yes i did those icons are there
  • OK, I don't think DS has been creating a desktop icon - at least on upgrade isntalls - for some time, I always used to delete them (it's already pinned to my task bar) and don't recall having to do so recently. You can always make your own icon by dragging the application file from the isntall directory to your desktop.
    its not installing in dim it takes two seconds to install
    then it says in dim its installed
  • And it isn't running if you click its entry in Start>Daz 3D?
    i cant even find the launch icon
  • What di you mean by
    i have 4.10 installed but i did that manually
    is there a ,manually install for 4.11?
  • No, betas have to be installed through Install Manager to make sure they can coexist with the release version.
    ok so i should stick with 4.10 for now play it safe ?
  • The betas are separate from the release build  -that's one of the things that isntalling through DIM is for - so it shouldn't be a matter of being safe.
    ok so i should stay with 4.10 now untill 4.11 is released manually ?
  • That's up to you, we don't know when the 4.11 series will become a general release so there's no knowing how long a wait it will be.
    i still cant install 4.11 in dim at all
  • But it is showing as installed? If you right-click on it in the Installed tab and select Show Installed Files from the menu you will get a window with clickable links listing the file locations - if you use those to open a file browser are the fiels there, and can you launch DS from the application file in that folder?
    i cant install 4.10 in dim either i don’t understand whats going on
  • What happened when you tried my steps above? Or is it actually giving an error in DIM and not installing?
    no no error you just see the bar fill up when downloading and then the install bar fills up  and thats it
    nothing else happens then when i click on the install tab  its there in the list as installed but no icon on the desktop
  • OK, but if you right-click and seelct View Installed files, then use the link to go to the folder do you find, and can you run, the application? The desktop shortcut is just that - a shortcut, it isn't actually a vital part of the application.
    no the window is empty
    it still wont install i dont know what the hell is going on  now when i open it it gets stuck at powerpose tools loaded
    i hate this i really do
