UberSurface2 Layered Shader
Hi,
Does the "UberSurface2 Layered Shader" work in Daz Studio 4.10?  I believe I've installed all of it's files correctly, but when I apply the UberSurface2 base shader to the surface of say, a primitive, the surface parameters are truncated a lot so that there's only Diffuse Color, Opacity Strength, UV set, Smooth and Angle.  I also have a product called "Lumina Materials Library" (which apparently depends on the UberSurface2 Layered Shader) and none of these work either.  Do these products work at all now??
  • The shader is applying correctly for me in 4.10.0.123. How did you install?
  • Stretch65Stretch65 Posts: 176
    Sorry Richard, I should have used the Install Manager.  Instead I used the manual download which gave me a .exe installer - it didn't put the necessary scripts in my Daz roaming directory.  It's all working now.  Thanks.
