send the clones in... WHAT IS THIS? AND HOW DO I MAKE IT RUN?!?
octobusoctobus Posts: 117
hi folks...
yesterday i downloaded "send the clone in"
i installed like the installer recommended it into the application folder
i found this strange but i did
in DS4.6 i did not find a way to open a panel or anything to open the thing
so i unstalled and restalled into the plugin folder of DAZ in hope and in order to make it run
still nothing
anybody knows where to install it and how to open a dialog to work with it?
thanks
o.
  • octobusoctobus Posts: 117
    hi there,
    i have downloaded and installed send in the clones
    it had been installed by default into the plugin folder of DAZ
    when i open daz than i don´t see how to open this
    wouldn´t i have a pane? how can i work with it
    i don´t see through
    pls help
    thanks
    olaf
  • NeilV_1NeilV_1 Posts: 442
    I only have the DS3 version and I find that in my DS 3 content library under Scripts/Utilities then with an Item selected I double click the script (click the icon) to run it to get the dialogue box to pop up. I presume tithe DS4 version runs the same way.
  • LindseyLindsey Posts: 2,017
    edited September 2013
    Scripts>Utilities>SendinTheClones DS4Send in the Clones is not a plugin, it's a script. It should be installed like regular "content" into My Library (or whatever your install folder is for content).
    You'll find it in DAZ Studio Formats: Scripts>Utilities>SendinTheClones DS4 or SendinTheClones DS4 Pro depending on which version you purchased. Just launch the icon in that folder which will bring up a Send in the Clones window.
    There should be a User Guide in PDF format in your My Library (or whatever your install folder is for content) ReadMe's folder. The document is either 15235_sendintheclonesds4.pdf or 15235_sendintheclonesds4pro.pdf
    You can also find this information in the DAZ Wiki docs:
    Send in the Clones DS4: http://docs.daz3d.com/doku.php/public/read_me/index/15236/start
    Send in the Clones DS4 Pro: http://docs.daz3d.com/doku.php/public/read_me/index/15235/start
    Hope this gets you on the right track!
    Post edited by Lindsey on
    thanks
    o.
    thanks... this worked so far... would you know a beginner tut?
    all i can find is advanced... and right now i find it a hard nut to crack just to duplicate a single item like a sword
    thanks again
    o.+
    Merged your two threads. Please don't make duplicate threads on the same subject as this means people are trying to help you in two places, and sometimes will mean duplicated answers as well.
    It says on the Product Page :
    •Short Tutorial in PDF format
    Have you looked at that?
    thanks... had a review to the tutorial...
    this is too high
    i would suggest every beginner NOT to download this product
    just doesn´t make sence
    the developer should have a look at other application
    for instance the partical replicator for after effect
    this prooves it is possible to make it easy
    i give up on send the clones in
    wasted money
    grrrr
  • Richard HaseltineRichard Haseltine Posts: 111,371
    You need to bear in mind that this is a script, to plug a gap in the capabilities of DAZ Studio. It isn't intended as a general purpose replicator system, such as you might find in a full 3D suite. If you are unhappy with it or don't feel it meets your needs then you can request a refund as long as it's less than thirty days since you purchased.
