polygon group editor in ds4.6 with imac
3djoji3djoji Posts: 1,125
I've the souvenir that to select additionnal polys I just hit the ctrl key during the selection But, strangely, this ctrl key doesn't work with this version. Is ther something i've missed? Is there anybody who knows how to select supplemental poly on an existing selection when using the polygon group editor and working with a mac?
  • Richard HaseltineRichard Haseltine Posts: 111,867
    Have you checked that the shortcut is set correctly, and that it doesn't conflict with anything else, in Window>Workspace>Customise?
  • 3djoji3djoji Posts: 1,125
    edited August 2013
    so sorry, in the daz studio version I have (for mac) I don't get this command..?
    I have well a customize daz studio where I can find some shortcut but no ctrl key for the poly selection...
    602 x 695 - 128K
    509 x 271 - 44K
    Post edited by 3djoji on
    edited August 2013
    I didn't find the solution as it is well no documented: on mac, no ctrl key is possible but on version 4.0, the rectangle selection acts well : each selection is added to the previous ones. But on later version, this was no more possible :(
    If you are using an old layout, inherited from previous installations, then it may still be Edit>Customise. In that case, as long as you don't have too many customisations of your own, it may be worth reloading one of the default layouts and seeing if that helps - but remember that if you are looking at the standard short cut keys listed in tutorials, ctrl on Windows becomes cmd on a Mac (and alt becomes opt).
    Thank you , you get the solution and I am always afraid of all the things we don't know really as stupid users. I had an old layout inherit from past versions. I didn't customize any of them and never thought that I've to reinit this layout each time I upgrade the DS version. All is in place and work well now. Thank you again for the attention you paid to my stupid problem :)
