Fast copy the shaders settings to another surface?
handel_035c4ce6
What I mean - I made a bikini set from 2 parts. Both parts use the same shader. I experimented with the settings of shader of the top part until I got satisfactory result. Now I have to input the same settings on the bottom part. So can I save the settings from the top and assign them to the bottom part? I tried saving them as "shader preset" but it looks it assignes the shader itself but not the settings of the sliders?
Post edited by handel_035c4ce6 on
A Shader preset should do both by default. You can also justa ply the base sahder, then use the Copy Surface/Paste to Surfaces commands from the Edit menu or the Surfaces pane option menu to transfer the settings.
Nice! Thanks you.
