White eyes in G8M renders
RychardesRealm
I've worked on two G8M characters over the past few weeks which have white eyes after render (brand new to Daz3D), first one I figured I'd find out later what happened (really tired when I noticed the white eyes). The second time was last night. I have worked on at least one other G8M character using Edward 8 with no issues. I cannot recall if the first white eyed character was built off of the G8M base, last night was. I have not stumbled across this in other versions, G3M, M4, G2, etc.
Thanx for your attention.
Rycharde
Iray or 3Delight renders? (Iray is the default.)
I follow default and I set up Iray when the option is given. I have not tried 3Delight as yet.
Just did another G8M base character along with G8F base, V4, and M4 for comparison. Only the G8M had white eyes.
It is the Genesis 8 Basic Male you are loading, not the Dev Load?
Basic. Never have used the Dev Load.
I'm not sure what could do this - you say you are using the defaults, but have you clicked the Defaults button in the Editor tab of the Render Settings pane?
Did so for other reasons, but yes, I clicked the default button at least once during this process.
