Render issue with G8F Anatomical Elements...line around the area
Hello everybody,
like title suggests I've an issue with render of  Genesis 8 female characters in genitalia area. I've noticed it because I rendered a character with a bikini that expose the higher part of pubic area and in render appear a line without texture...so i tried to render her naked and is all around the pubic area this line...I already tried to apply again full body maps, nothing change.
I can solve the problem with Photoshop but I would like to know if there is a solution for have all correct direct in render...maybe I make mistake but I don't know where.
Thank you very much.
309 x 55 - 14K
Post edited by Chohole on
  • Iray or 3Delight? Are you sure the materials for the anatomical elements match thos for the base (both Iray or bot 3Delight, for example, and no additional modifiers such as SSS or Translucency Amount applied to only one)?
    Check to see if the various skin surfaces are chromatic instead of mono SSS
  • First of all thank you very much for your answers.
    3Delight (IBL Master light), I've double checked the body skin surface and female genitalia surface and the both have the same parameters, and the booth have shader AoA subsurface, but I've tried to apply again to my character the RSL skin all map of Elizabeth HD for Victoria 8 and also tried Rebecca RSL skin map and Victoria skin map...saved...opened again...rendered and still the same issue. I didn't have this issue before...only because my characters never dressed bikini...but still I need to solve this, if possible.
