tattoos too pale [Solved]
AbnerKAbnerK Posts: 718
Hi,
I changed the skin on this character and reapplied the tatoos, but the tattoos are now really pale. I've tried everything I can think of but nothing works. What do you think could be going wong and how can I fix it?
See attached.
Thanks
700 x 900 - 489K
Post edited by AbnerK on
  • nemesis10nemesis10 Posts: 4,009
    The tatooo should be on both the images for the base color and the translucency (using multiply).
  • AbnerKAbnerK Posts: 718
    I didn't check that because I used tatts from the Smart Content pane, however they are applied correctly using multiplactive blend (multiply is Photoshop jargon)
    edited October 2018
    Having said that the torso diffuse map was applied in  several other places namely top coat curve (both) and transmitted colour, for ease I set up the Base Color using the LIE then after Accepting it, I single clicked on that Base color mask tab and noted the new image ticked then selected the same new image for the rest of the tabs that were using the diffuse map for that surface, repeating for the arms and legs (no tatts on the face)
