SOLVED - dForceMultiDressSystemforGenesis8Females query re adding textures
WilmapWilmap Posts: 2,917
edited September 2018 in The Commons
This is a great product but I would like to know how you can add your own textures.
Using a seamless tile works OK, but if I use the template with a texture added, it doesn't. It looks ok until you render it and then the template is tiled. In the Surfaces panel tiling is set to 1.
Anyone any ideas please?
Post edited by Wilmap on
    For Iray there's also a per-image tiling setting, in the Image Editor dialogue. I don't knoww hy it would be more than 1 initially, but it does sound like the issue.
  • WilmapWilmap Posts: 2,917
    Thank you Richard, that was the problem.  it was set at 5!
  • BlueIreneBlueIrene Posts: 1,318
    What does a pattterned shader look like on the dress? Is there much distortion in areas like the bust, for example?
