When Clothes Go Bad (A quick fix for 3D animators)
Sci Fi Funk
http://www.youtube.com/watch?v=BbE67LFCVoU
A fix for Carrara / Poser figures if their clothes do not follow the figure they are conformed to anymore.
This is one of those bugs in Carrara (and other poser related software?) where if you know it, you are ok. If not you might be perplexed for some time.
In the solution demo I show clothes moving differently to the figure they are attached to. I believe this occurs in Carrara when the clothes have been grouped within the figure. There will be other reasons as well.
Whatever the reason, the solution is the same. Remove and add afresh. This will fix the problem.
more info
http://www.scififunk.com
http://www.facebook.com/scififunk
Thank you for this tip. I don't know why I had not been to your site earlier, but I have it bookmarked now.
Thanks AtticAnne. I must update my list of tutorials on the site. I'll do that tonight. Also I put little bits of info (as I learn them) the facebook page "scififunk"
SciFi, you are hilarious! I not only found it very informative, but ended up giggling all the way through. Well done, going to have to check your other tuts for sure
Thanks Jonstark. :) More to come as and when I get stuck on a problem. (This is what motivates me share so that others won't get stuck plus I have a reference for the future). Now and again I can't help mucking about a bit. ha ha.
