Is it possible to remove the morph preset name from export?
When you export your model and import into another program, the morphs come up as Genesis8Male_(MORPH NAME) Is it possible to some how remove the preset name? I need specific morph names for a plugin I'm using in another program.
  • JD_MortalJD_Mortal Posts: 760
    edited September 2018
    You may be able to try hand-editing, depending on the file output you are using for the export. If the data file is just text. (or a zipped text-file)
    Even though a file says OBJ or DSF, etc... Many are just standard text files. Try opening it with notepad. WARNING, files may be real large, as they contain a LOT of point-data and object data. (You may have to unzip/unrar the file, in some cases. Some files are compressed text files or folders. Then you can edit and zip/rar them again, to finish the loop and use the file as intended.)
    They are named so the file can be used by Daz, as an import. If you try to import it to daz after changing the names, it will/may complain about missing morphs. However, if this is just a one-way export, never going to return back to Daz, then you can do what you want with the names inside.
    Post edited by JD_Mortal on
