Can't use tutorial because Taskbar won't hide
in New Users
I can't click continue on the interactive tutorial because my windows taskbar is blocking it, and I can't move the tab around so i can click it. I went through all the basics, making sure I had auto hide on in settings, restarted windows explorer, and made sure there wasn't an app keeping it open. Then i realized that my task bar hides in all other apps except daz. Is it something to do with daz causing it? And if it is, can it be fixed, or make a way so the tutorial windows can move dragged around your window so you can move it to click the continue button?
I don't have to do it for space reasons, but I do have the Task Bar set to Auto Hide and it does work in DS. In the meantime, you should be able to use tab to move the focus caret to the hidden button and then hit the space bar to press it.
Thanks dude! The tab/space trick worked!
