Where is the "dForce Simulation::Influence Weights" map?
Hello!
I'm trying to follow this tutorial to add dForce to a cloth: https://www.daz3d.com/forums/discussion/203081/dforce-start-here#latest
At one point, it's said that I should select "dForce Simulation::Influence Weights" from a dropdown menu.
However, I don't see this, and this map hasn't been added to my maps yet.
The one map that is shown in the screenshot was added when I selected the only available option ("<New Push Modifier>").
What might be the issue here?
Thank you!
  • MadaMada Posts: 2,079
    edited September 2018
    Did you create a dForce Modifier Weight node first? Also make sure you have the garment selected when you create the weight node. :)
    Post edited by Mada on
  • @Mada Thank you very much, I did it from scratch:
    I selected the cloth.
    I clicked Edit->Object->Geometry->Add dForce Modifier: Dynamic Surface.
    With the cloth still selected, I clicked
    Create->New dForce Modifier Weight Node
    DAZ automatically selected it.
    Then in the Tool Settings pane, the desired map was already selected.
    Great!
    1914 x 1032 - 324K
