Number of iterations jumping backwards and forwards [Solved]
AbnerK
Hi,
can anyone explain this weird log report on a spot render?
2018-09-23 23:51:51.059 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 01722 iterations after 16269.576s.
2018-09-23 23:51:51.061 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00334 iterations after 16220.055s.
2018-09-23 23:56:40.898 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00335 iterations after 16509.891s.
2018-09-23 23:56:40.997 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 01752 iterations after 16559.514s.
2018-09-23 23:56:44.554 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00336 iterations after 16513.548s.
2018-09-24 00:05:36.145 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00337 iterations after 17045.139s.
2018-09-24 00:05:36.183 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 01819 iterations after 17094.700s.
2018-09-24 00:10:27.948 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 01857 iterations after 17386.465s.
2018-09-24 00:15:33.920 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00338 iterations after 17642.914s.
2018-09-24 00:15:33.979 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 01896 iterations after 17692.496s.
This is just before I canceled it. This took 4.5 hours compared with the previous one done in 2.5 hr. This was in a separate window while the first was in the preview window though, same render settings, this was on the dark side of the figure though and the previous, quicker render, on the brighter side. I was doing a spot render because, the whole render, the eye's were awful compared to the rest of the image which, was perfect in no time. I'd tweaked the settings on the eyes to get more reflections though. But the main things is why is it jumping from the 1000's back to 300's?
Thanks
You said you were doing a spot render - maybe that was the source of the second set of numbers. It looks like DS was running two renders in parallel. (i.e. one set of numbers for one render, another for the other.)
Yeah, that was my thought but it wasn't storing or displaying a second render. The preview pane was clear as if doing a main render. I couldn't see any explanation for it.
Thanks
Did you have your Aux Viewport set to Iray?
No, I tend not to use it.
Just to mark this solved. Don't start a render from the Viewport set to Iray. Choose any other first as it will continue to render in the background using up RAM even if it looks like it's doing nothing. Daz knows and doesn't consider it a bug.
