Trasfering V4 UV Mapps to G2F Genitals
timnaastimnaas Posts: 123
OK, I have being trying this with no luck at all. I have the Victoria 4 for Genesis 2 Female http://www.daz3d.com/new-releases/victoria-4-for-genesis-2-female but it doesn't seem to work with the g2f genitals. I can't seem to find a procedure in doing this or I missed it some where. Any info would be great of point me to someone that had done this.
Thanks
  • JaderailJaderail Posts: 0
    Convert the V4 Texture to duf format. Load the new Torso duf texture map on the Gens. That should be all that's needed.
  • timnaastimnaas Posts: 123
    Tried that, it doesn't work. The textures do not blend in. I does not line up properly and there is no way to "re-set" the UV's
    edited August 2013
    timnaas said:
    Tried that, it doesn't work. The textures do not blend in. I does not line up properly and there is no way to "re-set" the UV'sAH!! Okay I did not know the G2F/V6 Gen's did not support the proper UV's. That is a issue. I never would have known as I do not do those type of renders very often any more.
    Could you Send a Support Ticket and explain the ITEM does not support all the proper UV's it should? I'm not sure it is supposed to as V4 is a add on support but you can only ask and see.
    Post edited by Jaderail on
