Genesis Eyes Stop Obeying 'Point At'
OstadanOstadan Posts: 1,133
When I save and restore a Genesis figure as a subset, sometimes the 'point at' control for the eyes, a very useful tool, stops working. Is this something that other people have experienced, or have I broken something?
    edited August 2013
    I do not know clear, about your case.
    but about ds 4.5 product ver, when you zero figure, it change point-at value to zero too.
    it is no meaning. because default point at-value need to 1.
    and user may only need on and off.
    there was bug report which made by me.
    but now user can not check bug wihch reported by other user.
    about ds new beta, now if you set zero-figure, point at-value not change.
    but I did not check restore figure,, usually restore figure work to restore all value to memorized default value.
    so that if you change point at value to zero without intention,(by using zero figure etc)
    and tweak something > memorize figure>it change and record current value as default value
    then restore figure, your point at can not work. I think without you set point at value again.
    to correct your default point at value,, change point at value to one, then memorize figure.
    it re-record the point at value to 1 again. then save it as subset, it may keep point at value I think.
    678 x 507 - 63K
    Post edited by kitakoredaz on
