Commercial: DP Genesis 2 Female(s) Shaders Bundle Save 30%
ringo monfort
http://www.daz3d.com/new-releases/dp-genesis-2-female-s-shaders-bundle
Save 30%
DP Genesis 2 Female(s) Shaders Bundle comes with 15 stunning skin shaders for Genesis 2 Female figures: Victoria 6, Gia 6 and The Girl 6. This product takes advantage of Carrara's most advanced shader features to create natural and photorealistic looking skin shaders. Add a striking look to your renders with DP Genesis 2 Female(s) Shaders Bundle.
500 x 650 - 233K
500 x 650 - 128K
500 x 650 - 152K
500 x 650 - 183K
500 x 650 - 212K
Post edited by ringo monfort on
Additional render images of The Girl 6.
Additional images.
Additional renders.
hello! i just buy them, but, as they are zipped, the DIM doesn't install them, and if I had manually, (add folder, in the shader room), it doesn't work, asking for a JPG... what I'm doing wrong???
Bought these as well and they showed up fine for me within DIM and also did install properly. On my Mac they installed within /Presets/Shaders/RingoMonfort directory. For the texture files Carrara probably needs an appropriate Runtime with the respective e.g. Gia textures to find them? I am rather new to Carrara, so still a bit uncertain about the whole content management thing there :)
Hi,
This the MAC version of the shaders? The shader is/are looking for the folder that contains the texture maps for the particular figure.
For example Victoria 6 on my PC in windows for me they are under:
My Documents/DAZ 3D/Studio/My Library/Runtime/Textures/DAZ/Characters/Genesis2/Victoria6
If you know where in the MAC the runtime folder is install you may direct the shader to that folder.
Ringo
no, I have a pc!!
For the PC they don't come in ZIP format they have an installer. maybe you downloaded the MAC version.
yes, I've seen, but each time I try to use DIM, I have that message... but Dim is working without problem on other installs... so it was the reason I want to install the shaders manually!... Maybe I don't understand something...mmm, I'm sure I don't understand something, in fact!
In the install Manager you need to setup the path for Carrara 8.5 check out the first image and see the red arrow. Click on the circle that it points and than you will get what is on image 2. Image 2 shows you were you need to setup the path for Carrara 8.5.
The Girl 6
The Girl 6 rendered using HDRI, Global Illumination, Indirect Lighting.
Victoria 6 in Carrara 8.5 with HDRI, Indirect Lighting, Global Illumination.
