IRAY won't start
Hi, ive always used IRAY but just recently, when i set a render going, it won't start...it sit's there and does nothing. Ive reset the settings from what I had put in, and still nothing. I can use GPU, and 3d Delight...but for some reason IRAY isn't. I have restarted the program sometimes as many as 5 or 6 times, and i can get lucky and it will start, but i wanted to know if there's been an upgrade recently, or if there's something I've missed or not had ticked that I didn't know about. Thank you in advance for your help
  • Has your driver version changed? What GPU are you using? Have you checked the end of the log file after an attempt to render?
  • PetercatPetercat Posts: 2,324
    What version of Studio are you using?
    Many newer things will lock Studio up if you try and render them in older versions.
    I have to return Realistic Tears for that reason, and I've returned a couple of environments as well.
  • it's the latest version, and this thing has recently started. I don't believe i've changed anything.
  • Windows Update may have changed the driver for you. Help>Troubleshooting>About Your Video card will tell you waht you currently have.
