Facial expression Keyframes?!! Where are they?
So I use Keymate to animate my genesis characters…
There are keyframe options for every part of the body except facial expressions.
This is problematic because I will build an animation… then on occasion I will need to re-adjust the animation and move some keyframes around. But when I do this… the facial expressions that I added will always stay in the same place on the timeline…
So in short…
Where the heck are the facial keyframes stored on the timeline?! And how can I move them around?
Cheers&Beers;
-Harvest
You need to set "TRSV" in keymate, to remove facial [removed]and morphs for genesis) key .
TRSV can show you morph value too.
then expand head node, on left pane of Keymate, then remove keys in channells of "value" section.
which you hope to delete.
if you select genesis head node, the keys are visible on daz timeline too,
even though you set keymate "TR" or "TRS",
but if you delete the key on daz timeline,
it may remove all key recorded assigend witht head node. I think you do not hope so.
Thank you, Bear.
That was a very simple solution.
And I am all the wiser for it.
Cheers&Beers;
-Harvest
