Morphing
I was thinknig of an idea of creating a character that had an abnormal body-frame -- freaky long arms and legs.  When I attempt to lengthen the arms and legs, I hit a length limit that I cannot get around.  I had tried to enter in 200% or something into the display to get around it, but no good.
  • SixDsSixDs Posts: 2,384
    edited September 2018
    Most morph sliders come with default limits set that correspond to some arbitrary range of human anatomy. However, those limits can be adjusted or removed altogether if you wish. If you click on the little "gear" icon for the morph slider, a popup will open - select Parameter Settings. A new window will open which is largely self-explanatory. You can uncheck the little box next to Use Limits to remove limits altogether, or you may enter new new minimum or maximum values if you prefer.
    Post edited by SixDs on
