Can I add a Propagating Dial to Hairs?
Is it possible to add a propagating dial to hairs so they fit larger headed characters? Some hairs are not following the size of the heads and I want to fix that
  • Are these on their original figure or AutoFitted to a different figure?
  • carrie58carrie58 Posts: 4,171
    On the original figures
  • Well, if the hair has its own bones you could just select all of them and scale at once. If it's using the bones of the figure that probably won't work correctly, and a dForm may be the answer with the Field enclosing the lower portions, where it isn't getting the head scaling.
    Thank you Richard I'll try that
