Pretty BAD Angels Secrets 2 Lingeri in 4K
xXQuatroXx
This toppic is about this release: https://www.daz3d.com/angels-secrets-2-lingerie-for-genesis-8-females
Think twice before buying it.
It looks pretty amazing in non upclose renders but at up close renders..... boy thats pretty bad....
Took this pic from 96% full 4K render upclose,,,, only captured the brah...
you can see the skin is still smooth where the brah shows high loss in texture even at SUBD L4
(not onl the model on SubD L4 but clothing aswell)
https://gyazo.com/b7db904cdfe3eb28f55a66dbaca0b726
Just thought i'd share this major disapointment.
But atleast the non zoom out versions look pretty great....so there is that.
Post edited by xXQuatroXx on
What are your render settings?
Render paremeters on the Brah are:
Res lvl = high (its not on base)
view subD = 1
Render subD = 4 (High or on lvl 1 doesnt seem to have much effect)
SubD algorithm = catmark
Edge interpolation = Sharp edges
SubD normals = Smoothed
Smoothing type = generic
Render settings:
4K / photoreal
render quality = 1 / quality enabled (higher doesn't have any effect on the brah)
conv. ratio = 98%
Max samples = 10000
Max time = 28800
Didnt touch any oprimization settings
Filtering
firefly = on
Rest is off
Spectral rendering enable = off
Rest of the render settings arent important
What more do you wish to know?
I'm not sure what else could affect it - but the aliasing is so strong that it would probably show in the promo images if it was a fundamental part of the outfit. Unfortunately I don't have the set to compare.
