Why does my V4 eyes go weird and get huge when i REMOVE a Head morph?
nokoteb99nokoteb99 Posts: 943
When i have applied a character morph,,, the only way to remove it fully and go back to the Base V4 shape is by using the included(in the character morph i bought) REMOVE pose. It removes the head morph.
But in my case, i dont know if this just happens with my specific character, but it makes the eyes grow, and also the eyes point down.
and i'm stuck, i dont know how to fix this to go back to nomal forward pointing eyes.
There is no eye rotation dials on the v4, and i checked the Eye SIDE-SIDE, eye-UP DOWN V4 MOrpsh++ that i have injected in my v4
but they're at 0.0% . So i dont know whta to do.
Reason im' doing this is cause i already made bunch of characters i just want to change the face.
478 x 505 - 206K
  • nokoteb99nokoteb99 Posts: 943
    Here's another pic. INJ the Head morph to V4, then removed it and this was the result
    376 x 464 - 159K
    By the way i'm on DAZ 4.6 pro. recently moved to it. I used to use DAZ 3
    Guys. well this is the character to which i change from V4 Base.. and then when i remove the hEAD inj i, it does go back to Base v4 head but
    it keeps the eyes weird like that.
    And i think i know what it is. You can see in the picture. When it changes from V4 to Asuka(that's the character morph) the head is like small and the eyballs shift down .
    But seems when i revert back to V4 bass by REMOVING HEAD INJ,,,, the eyeballs don't bo back up to V4 head level. they stay down.
    And doesn't seem there's anything i can do, is there? cause tehre are no EyeBall TRANS Y dials or nothing
    453 x 474 - 169K
    edited August 2013
    It would really help to know what character it is that's giving you issues.
    Some morphs tend to do strange things to the eyes. Check to see if by chance the author included some sort of Eye Fix injection/morph.
    Post edited by Lissa_xyz on
    Yeah i told you it's Asuka http://www.renderosity.com/mod/bcs/d2-asuka-v4/82181
    edited August 2013
    Welll i think i got it :)
    you just do this
    1. memorize shape( so it memorizes the body shape)
    2. Zero figure (changes back to v4 base and face too and eyes are fine now looking straight)
    3. we want the same body back but the head we want it to remain V4 base head.
    So now just do Restore Shape.
    That works :) Well it worked the several tests i did just now
    Post edited by nokoteb99 on
    You should be able to fix it without having to memorize the figure. Click one eye, and then ctrl-click the other eye so you select them both. Under Parameters > General, change the translations and such so that they're in place where you want them.
    Sorry I missed that bit.
    you just do this
    Well it didn't quite work
    The eyes still dont' work, I noticed they didn't work, cause when i ZEROED it it was fine, but when i applied a totally different morph, the eyes went back to looking down
    Well that technique works fine. Just for a few characters, i get the Eyes weird/down but for most they work . So i'm happy now, thanks everybody
