Problems with Model Room
EddyMI3DEddyMI3D Posts: 365
edited August 2013 in Carrara Discussion
I have problems to work on things in the Model Room like objects, Surface Replicators, Particles,. Figures (People and Clothing) do work.
I have recent C8.5P on Win7-64
Maybe a faulty Extension?
Thanks for Help
Eddy
Post edited by EddyMI3D on
    Hi Eddy!
    Can you try and explain the problems you're having with these areas. I can tell English is not your first language and it may difficult, so if there are pictures of messages or anything else that might help explain the problems, please post those as well.
    Thanks.
  • EddyMI3DEddyMI3D Posts: 365
    Uhhh, I found it myself.
    I'm using a dual screen system and the replicator menu window was hidden behind the Sequencer Window.
    Thank you for your efforts, EP.
    Eddy
  • DartanbeckDartanbeck Posts: 22,154
    Okay, you found what? What problems are you having?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,714
    would you believe I have done that accidently on a single monitor with panes undocked
    (they do not go out of the main window's bounds but can obscure each other)
