can I use textures for Genesis 1 on Genesis 2
starionwolfstarionwolf Posts: 3,670
I have an easy question. Can I use skin textures for Genesis 1 on Genesis 2 basic female? I remember reading a thread that says we can't use V4 skins on Genesis 2 female(s). I missed the thread that talked about using old skin textures on Genesis 2 female.
Because I don't have any extra money to buy skin textures just for Genesis 2 female I thought I would save some money by using the textures of Genesis 1 that I already have.
I should've bookmarked the thread. Yes, I even did a search for the thread but I couldn't find it. Thank you for your patience and understanding.
bye
Post edited by starionwolf on
  • fixmypcmikefixmypcmike Posts: 19,729
    You can use textures mapped for the V5 UVset on G2F
  • bringhobringho Posts: 241
    To elaborate a bit on this answer:
    Genesis2FemaleStarterEssentials includes 2 UV maps called "Base Female" and "Victoria 5".
    I have not put the Victoria 5 uv map from this figure on top of the one from the original Victoria 5 figure but since the differences between Genesis and Genesis 2 Female are quite small I'd be very surprised if there were any problematic differences.
    However, please note that not all morphs/characters sold as "Victoria 5" compatible use the Victoria 5 uv map.
    Some of them actually use the V4 uv map... But thanks to MallenLane there is a Victoria 4 uv map available for Genesis 2 Female ;)
  • starionwolfstarionwolf Posts: 3,670
    ok, thanks for the information. I forgot about Victoria 4 for Genesis 2 Female and Victoria 5's UV Maps.
    Bree and Olivia are the only skins that has a UV map set for Victoria 5. Lora has a UV map set for Victoria 4. I will buy Victoria 4 for Genesis 2 Female soon.
    Oh yeah, I finally found the option to select a UV map for Genesis 2. You are right, Genesis 2 accepts V5's maps.
    I just installed Genesis 2 female today so I was a bit confused.
    461 x 258 - 26K
    Richard Haseltine wrote an article about using Victoria 4 materials on Genesis 2 Female:
    http://www.daz3d.com/forums/discussion/17/P30/#365834
    I'm going to play with Genesis 2 female now.
    bye
