Embarrassingly simple DAZ Studio 4.6 Question - loading M4 shape into Genesis
ShaneWSmithShaneWSmith Posts: 636
Hi everyone,
I've been using Poser for many years now, and am trying to wrap my head around DAZ Studio 4.6 so I can export some Genesis clothing as CR2 files.
I've bought the M4/V4 shapes for Genesis (and they've been installed using the DAZ install manager), but damned if I can find out how to actually change the shape of the Genesis figure on the screen.
Can someone please do me a solid and walk me through it step-by-step?
Thanks!
  • IgnisSerpentusIgnisSerpentus Posts: 2,627
    Once the shapes are installed to DAZ Studio, you can find them under the shaping tab. If its not showing for you (its dependent on your UI choice) u can go to window/tabs/shaping to load that tab.
  • ShaneWSmithShaneWSmith Posts: 636
    Thanks, I've got that tab up, and it has a whole lot of options, but the DAZ morphs that I've bought and installed (Gen 3 Iconic and V4/M4) don't seem to be here...
  • Richard HaseltineRichard Haseltine Posts: 111,816
    Are you sure they were installed to a folder you are using as a DAZ Studio content directory - DIM has a different default from DS4, and although the newer versions add both an older version already installed won't. If so, select Genesis, then go to the Parameters pane, click All on the elft, and type Michael or Victoria into the filter box at the top - does the Gen 4 morph show up then?
  • riftwitchriftwitch Posts: 1,439
    When I first started using DIM, I couldn't find my new products either. After I changed the settings to point to My Library, the products were installed where I want them.
