How to fix mesh deformation after autofit
BubbleCloud
Sorry guys, I'm sure this issue has been covered here somewhere, but I guess I don't know how to google it
and find exactly what I want.
So, I am trying to learn basic things about modeling clothes for DAZ, and since my difficulty is not the modeling part, but making the cloth
to work properly inside DAZ, I thought to make some quick tests with an existing dress from my library.
I used Celia Dress for V4, exported as obj, I made the adjustments needed in Blender, exported as obj and then I used
edit-object-rigging-'Convert Prop to Figure' and the 'Fit to' command. I then made some morphs, all these for testing purposes, because I 've never made morphs
for anything, and anyway everything seemed to work fine, as I read many tutorials :P
My problem is that I don't know (and can't find a tutorial about) how to fix this deformation between the legs and breasts area
when the cloth is autofit in any other figure except G3F.
I'm sure there must a way, even though I noticed this deformation happens in many of the clothes I have in my library.
Does that mean that not even PAs haven't fixed that because there isn't a way?
P.S : I also tried to fix the dress exporting the dress after autofitting on Aiko7, but it is very deformed, almost cut in pieces
and I wasn't sure if this is a working way, because editing would change the dress' geometry.
Only way i know of is send it to Hexagon, but any modeller that has that has a smoothing brush to clean up the deformation and even after fixing it there may still be some depending on the propotions of the character it's fitted to but needs to be fitted to base model before doing this so when reimported transfer utility will rig it properly, may be other ways but I find this to be the quickest
I have tried to smooth it, but it didn't help, I want it to be as good as it fits on G3.
If I got this right: you mean to redo all the steps I did but this time using Aiko7?
And then what? How do I "tell" to DAZ how to autofit on Aiko and how on G3?
This isn't a simple morph , it's something else that I don't know what it is.
Have you tried geometry smoothing? >>>>
Thank you so much SilverDolphin!
It was so simple, I just didn't know it.
Glad it helped.
